has anyone ever seen a left hand turning 2 man post hole digger?
   / has anyone ever seen a left hand turning 2 man post hole digger? #1
glh
has anyone ever seen a left hand turning 2 man post hole digger? (its turning the rong way)
it ant got anyway to change the direction on the outside or the inside of the gearbox .
it runs great but i dont have a left handed auger for it nor can i find one or anyone that makes um
any ideas
thanks
gary...
   / has anyone ever seen a left hand turning 2 man post hole digger? #2
Is it a two stroke I am guessing?
Let me restate, I bet it is a two stroke and your timing is off, most likely a sheared flywheel key and it is happier running backwards.
That is my idea at least.
   / has anyone ever seen a left hand turning 2 man post hole digger? #3
My Eathquake has a coupling to the motor on the auger and a separate bit for the tip. Looks like you have the bits reversed. Turn the thing end for end maybe?
   / has anyone ever seen a left hand turning 2 man post hole digger? #4
I think I may have an answer to your question. In a single gear reduction system, the output direction is opposite to the input. In a double gear reduction system, the output direction turns the same as the input, or motor. I also have a left hand auger bit. Don't know what auger it was used with. There is no difference with the operation of the bit, it digs like the right turning bit. I also have the Earthquake auger head, and two auger bit. A hydraulic motor could turn either bit in the direction of the flutes, by reversing hyd flow.
yes it is a two stroke
and i do know you can run a 2 stroke both ways most of the time but the mag will only spark going one way on this one and you cant turn it around
the motor is turning the right way ( to the right )
and the way the gearbox is made the motor will only go on one way and only on one side
and even if i did turn it around i would still have the same problem
it has the motor shaft coming into the gear box with a gear on it going to another gear that go's yet again to another gear that go's to the gear that is on the shaft coming out that you connect the bit to
so four gears in all
motor turns to the right the next gear to the left the next gear to the right and the out put gear and shaft turning to the left
with no way of taken one out or putting one in
i cant take a pic of it right now because its at a friend of mine house about 35to 40 miles away were we had wanted to use it to drill about 16 holes with a bit i had from my first one.
lol we got everything ready put the bit on started it up started drilling and after about 5 minuets of pushing with all we had and only going in about 1.5 inch and thinking " man this is some really hard ground " looked at the bit and saw it turning the wrong way ( now i know why i got it for only 80 bux at the swap meet )
thanks guys i guess i'll look into making one for it
thanks gary...
   / has anyone ever seen a left hand turning 2 man post hole digger? #7
any ideas
thanks
gary...
Yes I own one! Many ice augers are Left Hand spiralling, with the power head turning counterclockwise to match. But there are some now-obsolete left hand auger bits and heads no longer made/no parts that, back in the 50's and even 60's, were EARTH AUGERS. Own one/no parts. Question: what is the diameter of your LH auger bit?
Guess at its overall length? You got my curiosity and I hope this helps answer your puzzle! Can you kindly let me know? Thanks, Leonardo Santi PS Sorry to be responding to your question so late, but I just joined today, Jan 28, 2014.
   / has anyone ever seen a left hand turning 2 man post hole digger? #8
Those were manufactured for only a short while as a post hole filler. The didn't work well with a post in the hole.
   / has anyone ever seen a left hand turning 2 man post hole digger? #9
I was thinking maybe it was Australian. Things turn backwards down under!
B&W Companion Sliding 5th Wheel Hitch (A53117)
B&W Companion...
2018 Chevrolet Tahoe SUV (A51694)
2018 Chevrolet...
2018 Infiniti QX60 SUV (A51694)
2018 Infiniti QX60...
1987 FRUEHAUF 8,000 GAL TRAILER (A53843)
1987 FRUEHAUF...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
Year: 2018 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 225,027 Plate: Body Type: 4 (A51692)
Year: 2018 Make...
