Anonymous Poster
Epic Contributor
- Joined
- Sep 27, 2005
- Messages
- 29,678
I went from a walk-behind 21" Honda to a BX2200 after we moved to a larger property two years ago. Skidding some logs and hauling cut firewood is something I'll need to do on our hilly seven acres. We've got heavily wooded land with a lot of elevation changes. Looking out the back second story window I can see about four upcroppings (ridges) in about 100 yards. I doubt I'd be skidding logs very far - just to move them off slopes to be cut to length.
As a beginner, I'm in need of basic info:
- where do you buy your chain/cable for skidding logs?
- any 3pt attachment needed or just hook the chain to the frame?
- had anybody mounted a power winch to pull logs (and extract BXs from mudpits)?
- can firewood carts articulate enough to go up and down short steep slopes?
- considering the tight spaces and relatively short distances, should I just do three runs with the FEL filled instead of trying to pull a firewood cart?
- tool + chainsaw carrier?
....thanks, Rich S.
p.s. I HIGHLY recommend the Jotul Oslo woodstove.
....thanks, Rich S.
