harvest king hyd-trans fluid
   / harvest king hyd-trans fluid #1
engelb77
new holland tc33d
anyone know if harvest king hyd-transmission fluid is good or bad? i was in farm and home today and seen it and i am about due for a hyd-transmission change on my tc33d.
   / harvest king hyd-trans fluid #2
   / harvest king hyd-trans fluid #3
As long as it meats your specs you can use it. I know some guys that have used that brand for years and rave pretty high about it. A lot of farmers speak highly of it as well, but note I don't have any experience with this fluid. I have last seen it around $50 for a 5-Gallon pail.
   / harvest king hyd-trans fluid #4
I have used it for ages in everything I own and it has worked fine! thanks; sonny
   / harvest king hyd-trans fluid #5
i agree.. if it meets the listed specs, it should be fine...
thanks for the replies guys
2003 CATERPILLAR D6R XW HI-TRACK CRAWLER DOZER (A51406)
2003 CATERPILLAR...
8' LARGE FENCE POSTS (APPROX. 20-25 PC) (A54757)
8' LARGE FENCE...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
