Harley rake:dimples or bars??
   / Harley rake:dimples or bars?? #1
Tags
Platinum Member
Connecticut
BX2360/ Kubota SVL90-2/ Kobelco 115SR/ Takeuchi TB260
I just wanted to get some feedback from you guys.I currently own a 6'Pro Harley power rake and it has the "bars" on the drum right now but they are just about at the point of needing replacement and before I go through the trouble of welding on new bars I wanted to know if anybody has used the rake with the carbide "dimples".I know that I can purchase those dimples and weld them on instead of bars.Any feedback on this would be appreciated.
   / Harley rake:dimples or bars?? #2
I have rented one with the carbide dimples and they worked fine, but I have never used one with the bars so I can't give any comparison
   / Harley rake:dimples or bars?? #3
It's gotta have Ape Hanger bars, of course! What else would a Harley have /w3tcompact/icons/grin.gif Oh, and forward controls...
   / Harley rake:dimples or bars?? #4
I have owned both rakes and unless you are always working with loose dirt the pro just won't do the job. With the pro I always had to disc or rototill to loosen up the dirt but with the carbide tips it works like a rototiller and let me tell you I work with 99 percent clay and it will tear it up no matter how hard packed it is. I liked the way the pro leveled and raked stone but I had to have loose dirt to make it work right. I asked about doing the same thing you are about to attempt and the people at Glen-Mac did not recommend it so I sold the pro and bought the carbide type. I do not remember what there reason was,hope this helps.budinohio
   / Harley rake:dimples or bars?? #5
I have experience with both kinds. The rake with the dimples or studs is definitely more versatile. It will loosen up hard packed soil, aggressively uproot rocks and vegetation. It can also be used to "freshen" gravel driveways.
The "Pro" model with square stock welded to the cylinder can do none of the above but can't be beat on loosened soil.
Glenmac does offer replacement drums for these machines, so you could have one of each. I am not sure of the cost or how quickly the could be interchanged.
   / Harley rake:dimples or bars?? #6
Will the Harley rake w/ dimples chew away stumps cut close to ground level? Thanks
Mutt
   / Harley rake:dimples or bars?? #7
Yes, if you beat on them long enough. The dimples are rounded, and do not cut into the wood easily. So they will work.
Countyline Single Row Plow (A50123)
Countyline Single...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
CFG Industrial SAII100 (A50123)
CFG Industrial...
Ford Super Duty FX4 Pickup Truck Bed (A51692)
Ford Super Duty...
