Hardibacker Joint Cmpd
   / Hardibacker Joint Cmpd #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
What kind of joint compound do you use with Hardibacker?
   / Hardibacker Joint Cmpd #2
A fiberglass mesh tape is placed across the joint, then you use an acrylic-modified thinset and press it into the joint, covering the tape. You can do this at the same time as tilesetting, or it can be done ahead of time and allowed to set. If allowed to set before tiling, any bumps in this joint filling can be ground down with a rubbing stone. This acrylic modified thinset has special additives to keep the mortar slightly flexible after installation. You can purchase regular thinset mortar and use latex admixture instead of water, or you can purchase modified thinset such as Custom Building Products. Further instructions can be seen at the <A target="_blank" HREF=http://www.hardibacker.com/>Hardibacker</A> website.
   / Hardibacker Joint Cmpd #3
Mike
Is Hardibacker a cement board product? If so, get the tape thats made for cement board, (not the regular stuff), then just use whatever mortar you are going to use to set your tile. I like versabond, it has a real fine grain and sets pretty fast.
SHF
2025 IR UNUSED Hydraulic Breaker (A53117)
2025 IR UNUSED...
2025 IR UNUSED Ripper (A53117)
2025 IR UNUSED...
2 windsor 351 inboard motors w/transmissions shafts rutters and props (A53424)
2 windsor 351...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A53473)
John Deere 5090E...
2017 Polaris 500 Ranger Diesel Utility Cart (A53421)
2017 Polaris 500...
