Rotary Cutter Hardee Rotary Cutter Replacement Blades
   / Hardee Rotary Cutter Replacement Blades #1
NCRetiree
Summerfield, NC
Kubota MX5100DT
I have a heavy duty Hardee 51/2 foot Rotary cutter. The blades are totally worn down and are about 21/2 inches shorter than new ones. The manufacturers tag is barely hanging on and unreadable so specific info is hard to assure plus it looks like it has been modified. I bought it used from a farmer that repaints them and then sells them.
My problem is getting replacement blades. I thought I ordered the correct ones from Agrisupply.com but I received bladed that are about 3 inches too long. Now I need to call them and see if they can help me in returning them and getting the right ones. I also ordered what I thought were new bolts only to recieve the bolt only, no washer or nut (what's up with that. doesn't everybody want bolt, washer and nut?).
Where's the best place to order 2 blades 1/2X 3X 23" CCW with 21/2 offset?
Thanks for your help. I was frustrated getting the old blades off, now I am frustrated getting new blades.:confused2:
   / Hardee Rotary Cutter Replacement Blades #2
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
KOHLER 24 HP ZT1 7000 SERIES (A50322)
KOHLER 24 HP ZT1...
Agway AccumuL8 Grabber (A50515)
Agway AccumuL8...
