hard starting CT235
/ hard starting CT235 #1
xfmrdude
Marmora, Ontario, Canada
Bobcat CT235
Hello all!. Was wondering if I could get a little help with a hard starting Bobcat CT235? My bobcat will roll over and roll over, it will pick up speed as it goes, lots of black smoke while it's trying to start and then finally it seems like it picks up on a few cylinders, and spits and sputters until it's running on all cylinders. Once it has run for 30 or 40 seconds it runs normal with power and no smoke. I've checked the preheaters with the resistance measurement given in the manual, and all three are ok. But I have noticed a leak in the middle cyl injector. Can't tell were it's coming from, but there is an obvious leak there. I have clean it up only to see the oil return around the injector. It doesn't appear to be spraying out, just a leak. The tractor has approximately 635 hrs and there was no paint on the head when i purchased it so I'm assuming there was issues before with the engine.
Should I start with a compression test first, or does it sound more like a fuel issue?
Any help would be greatly appreciated!!
/ hard starting CT235 #2
No answer, just a question. Has this condition come on suddenly or over a period of time?
Seems to me if it runs normal after cranking the problem could likely be in the glow plug area. I know I have tried cranking my 235 when cold without using the glow plugs and it has the symtoms you have described. Maybe try using a voltmeter at the glowplug while engine cold and key in on position making sure you are getting voltage to the glowplugs. Does your glowplug light come on when cranking cold?
Thanks Winston!
It has been getting progressively worse with the colder weather. But i did notice it the first time in the fall. The glow plug light does come on when I turn the key, and then times out and I turn the key to start. I have manually run the glow plugs longer, but didn't seem to make a difference.
/ hard starting CT235 #4
Easy thing to check voltage on the glow plugs just to eliminate that possibility
/ hard starting CT235 #5
In my mind I would check the fuel leak issue first and foremost. If problem still persists then move forward.
I removed the glow plugs today and found two shorted and one working. So the glow plugs it is, but the only thing is my dealer here wants $112.00 cdn ea. Any suggestions were to buy cheaper? I'm sure even to buy from the US with the exchange, shipping and duties it must be cheaper!
/ hard starting CT235 #8
Just curious, I can understand one of them dying young......
but two of them? seems odd to me
:confused3:
/ hard starting CT235 #9
Wonder what the temperature runs in Marmora during usage time? Brrrr
/ hard starting CT235 #10
I just looked at a CJ235 for sale. ~900 hours, no noticeable leaks, $11,500. Good price or not?? It seemed to start up a little rough, like knocking / coughing / white smoke for a few seconds, then after 5-10 seconds it was smooth, no smoke and sounded normal - like a diesel. Does this all sound normal for this engine at 900 hours?
/ hard starting CT235 #11
Don't know whether this was a cold start? If it was and glow plugs were not properly used you would get white smoke. Also a possibility the glow plugs are not all working. My CT235 has around 1400 hours and doesn't knock but these diesels do have a bit of a loud sound to them. No doubt, it could be classified as a knock from some. Personally, I would say it is a normal sound.
I gave $11,000 for mine 2 years ago so I think the price is reasonable.
/ hard starting CT235 #12
I'm going to go out on a limb here and assume you meant a CT 235. If so I would ask you if it included a loader and if it was a hydrostat or gear drive. Also your location will mean a lot when it comes to price. Assuming the tractor is in good condition with a loader within 100 miles or so of me here in the Midwest I would think that is a bit high. But good used tractors that are not tier 4 final are definitely in demand. And that is definitely a nice machine if the condition is good.
/ hard starting CT235 #13
Ah, yes, CT235, yes, loader + hydrostat. In face, here's the craigslist ad. Location: Bend, Oregon. Seemed to be good condition to me. Smooth running, except for forward / reverse pedal needed some oil - it didn't move easily. Otherwise seemed to be in good shape. Cooland looked clean, no leaks. Engine, undercarriage, pto all looked dry on the outside.
/ hard starting CT235 #14
I would want to know if it was stored inside or out
Sun and weather can be destructive to the plastic
Also if the go pedal is bad it can get expensive quick
/ hard starting CT235 #15
That rough running for a short time when first started with engine cold is normal especially if started before the glow pug light goes out, or if glow plugs are weak/faulty. This tractor has automatic glow plug. When key is turned to ON and engine temp below 85F (approximately) the glow plug controller will automatically come on for about 25 seconds then after starting the glow plugs will come again and stay on for another 15 - 20 seconds to help warm the combustion chambers.
/ hard starting CT235 #16
Did not catch what year it is but seem like a fair price. 900 hours is kinda like 35,000 miles on a car. Not enough to wear out much, especially if it has been maintained.
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
DEUTZ MARATHON...
2016 Yanmar VIO25 (A60462)
2016 Yanmar VIO25...
1459 (A57192)
1459 (A57192)
2019 CATERPILLAR 305E2 CR EXCAVATOR (A62129)
2019 CATERPILLAR...
