Oil & Fuel Hard Starting 1925 - oil pressure light
   / Hard Starting 1925 - oil pressure light #1
llapanowski
Today I had a hard time starting my 1925. When the key is put in the heat position the oil pressure light was not coming on. The Glow Plug light is coming on. If I play with it (turn off & try again) the oil pressure light comes on and the tractor starts with no problem. When the oil pressure does not come on then it is very difficult (if at all) to start. Any ideas?
   / Hard Starting 1925 - oil pressure light #2
ignition switch? dirty connections on relays, fuses etc.?
   / Hard Starting 1925 - oil pressure light #3
Ignition switch would be my guess... Does that unit have a key-off fuel solenoid?
soundguy
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2022 MGT CM11CUFT S/A Towable Concrete Mixer (A51691)
2022 MGT CM11CUFT...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
CAT Skid Steer (A50322)
CAT Skid Steer...
JLG 36AM-DC VERTICAL ELECTRIC PUSH AROUND MANLIFT (A51247)
JLG 36AM-DC...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
