Hard start Beaver
   / Hard start Beaver #1
SteveM
Upstate NY
Kubota B7100DT
I just acquired a clean well maintained Beaver, but with the temps in the 30's here it is harder to start than my other 2cyl diesels. Here is where things stand:
With my battery charger/jumper hooked up (to ensure I am not suffering a bad battery) I had to do 2 rounds of glow plug for about 1 full minute, then crank for nearly 10 seconds at full throttle - lots of smoke - and it reluctantly fired up /forums/images/graemlins/blush.gif. Once running it does not smoke at any RPM, only slight smoke when I jab at the throttle.
The glow plug indicator works, and the wires leading to the plugs look good.
1st question - how well do Beavers start cold?
2nd - how can I test that the plugs are working?
3rd - this machine has a plug in heater that seems to warm the intake (havent used) how long should such a thing be plugged in to be effective?
Thanks for all your help
- for background info, my previous Kubota and Hinimoto 2cyl diesels would start pretty quickly with just one round of 1minute glow, less than 5 seconds cranking.... /forums/images/graemlins/grin.gif
   / Hard start Beaver #2
I have an MT372D which is the same as your S370 Beaver. 2 cylinder diesel .It is almost impossible to start when it is below 40 degrees. I installed a block heater behind the starter in one of the freeze plug holes. Plug it in for an hour and it starts like it was summer . I have never heard of an "intake" heater . i would like to see a photo of that .
   / Hard start Beaver #3
Start troubleshooting this problem by having the compression checked. The manual calls for 455 lbs and you must have at least 400. This tractor is 25-30 years old and my guess is you don't know its history. If a previous owner had the same problem and used ether to start it, there is a good chance you could have a cracked piston or two. I see alot of them. We recently sold a S370 that we displayed outside our business. It started consistently with one heating of the glow plugs at temperatures from 20-40 degrees. So it is possible. Save time, start by measuring the compression. Email vppinc@rev.net or call 800-609-5110 if you want to discuss this further. Bill (check out our web site satohparts.com)
   / Hard start Beaver
Well perhaps I posted too soon. Thanks to our 10" of new snow, I had an excuse to play last nite. Plugged in the heater for about 4 hours, and the Beaver started instantly with virtually no smoke. It also should be noted I charged the battery overnight, and the glow plug indicator was much brighter as a result.
Thanks for all your help - I am still interested in doing a compression test - can the tester be rented? I have done this on gas engines, but on a diesel where to you attach the tester?
   / Hard start Beaver #5
I have never done the compression test but I would assume you would pull out one glow plug at a time and screw in the fitting there . Be careful that it doesn't start ! Auto Zone possibly rent one ? The compression is much higher than a gasoline engine so dont try to use one for that .
   / Hard start Beaver #6
Yes Al, it is measured thru the glow plug hole. This requires a compression guage that will read at least 455 lbs and is equipped with a 10mm adapter. You must remove all glow plugs before performing the test. We've been trying to locate a reasonably priced tester we could sell, but so far the supplier is dragging his feet. Bill
   / Hard start Beaver #7
I have several friends who own Beavers,they have all been hard to start when cold,thats one reason I bought a 3cyl. /forums/images/graemlins/grin.gif
   / Hard start Beaver #8
Starting in cold weather seems to be a common problem with the Beaver. Good to hear the block heater solved the problem.
1838 (A51248)
1838 (A51248)
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
Kubota LA853 Loader Arm (A51691)
Kubota LA853...
2021 Simex padding bucket, 8-9 ton class, like new (A52384)
2021 Simex padding...
