BearKiller
- Joined
- Aug 27, 2009
- Messages
- 230
I thought there were a couple threads around here to discuss H-F stuff, what is good and what sometimes is not.
I did a few searches and could not find those threads.
I keep two grease-guns, always loaded with Kendall Super-Blu L-427; one is a pistol-grip with a longish flexible hose for accessing Alemites that the rigid tube cannot; the other is a rigid tube lever-action for those easy to get straight in on Alemites.
Over the years, I have pieced and parted these old guns, using parts from two or three to make one servicable gun.
My last lever-action gun finally gave up the ghost and I had exhausted all my parts-swappers.
So, I bought #1703 from Harbor Freight.
Lever Action Grease Gun
I really like the little tab that locks the plunger-rod at all positions, making it much easier to retract the plunger.
ALAS, when I loaded a brand-new tube of Super-Blu, I could get no grease to pump; no amount of bleeding or reloading made any difference.
Harbor Freight being over 125 miles away and me needing the gun, I gave it a physical examination to ascertain the problem.
I inserted an empty grease tube into the barrel and discovered that the plunger would NOT enter the tube.
Further examination revealed that the rubber plunger seal was made with a rather fat protuding ridge around it's perimeter.
I could press the rubber gizmo into the end of the tube and the ridge would stop all forward progress.
SO, I took a pair of scissors and trimmed off this offending appendage, being careful to make a true cut.
I tested it with the empty tube in the gun and all worked as it should.
I reloaded the full tube, bled off the air, and now it will squirt grease across the shop.
So far, so good.
Before I dis-mantled and trimmed the seal, I tried to just swap the barrel/plunger assembly from one of my other guns.
I have always found these to interchange from one gun to another, regardless of brand.
Not so with the H-F unit, the barrel is just a hair slimmer and the female threads in the "head" will not screw onto the normal barrel.
I am certain that EVERY LAST ONE of these guns are going to be made wrong as the one I got was, so BEWARE that a little alteration is going to be imperative, before successful use of the gun.
So far, so good.
