hanging drywall
   / hanging drywall #1
abbub
I've seen people hanging drywall on TV and they position the drywall onto the wall and start driving screws. How do they know where the studs are without measuring?? Is there some trick i'm not aware of or are they just good??
   / hanging drywall #2
<font color=blue>Is there some trick i'm not aware of or are they just good??</font color=blue>
In simple terms, they are just good but you have to remember, it's still just TV. /w3tcompact/icons/wink.gif
In reality, if you want to mount drywall on an already covered wall surface, they sell these things called stud finders in hardware stores and in places like that. I've never thought much of these things. A good drywaller can tell where the studs are just by tapping the existing wall surface and listening to the 'tone' of the knock to determine if he's hit a stud or empty space. The greater dangers though are a) if you have irregular stud framing different from the normal 15-16" stud separation (this is especially prominant in older houses 'done over' by inexperienced home improvers or when state building codes were not in place) and b) figuring out where the behind the wall electrical lines are running. You hit one of these lines by accident.....and this will require yet a bit more extensive wall rehab. /w3tcompact/icons/grin.gif
.....Bob
   / hanging drywall #3
Don't forget about the "how did that water pipe get there" problem either.
   / hanging drywall #4
They're just good!
My version of that is to mark the stud locations on the ceiling and floor and then either chalkline the drywall, or eyeball it.
The pros get pretty good about eyeballing .... and you still find the occasional "miss" when repainting. Remember that television = editing ... tha's why they show all the fun bloopers at the end.
   / hanging drywall #5
Most construction is built with studs 16" on center and ceilings 24" on center. Drywall comes in 8' and 12' lengths, so on walls your splitting your sheet of drywall into 6ths or 9ths for walls. Same idea for ceilings.
The pros do miss, I taped drywall for a while during undergrad, they are just quick to load another screw into the gun and keep going. Some leave it to the taper to remove the loose screw -- jerks. /w3tcompact/icons/wink.gif
   / hanging drywall #6
I watched while some of our house was being "rocked". All I can say is they're VERY good! Four man crew. One screwing, one measuring, one cutting and the fourth helping to either measure or position/screw. And talk about fast!
In reality, it's not that hard to hit the studs without chalklines etc. I can't do it anywhere as well/fast as the pros, but with some attention to it you can get there /w3tcompact/icons/smile.gif
   / hanging drywall #7
I've hung a bit of drywall and taped and bedded too. It takes practice to hit a drywall nail "just so" and have it properly dimple the drywall but not crush it.
In anticipation of hanging some more drywall, I bought a cordless drywall screw gun with belt fed screws. How about that... a semi-auto scew pistol. It is almost as good as having three hands AND you don't drop any screws AND you dont get any metal slivers in your fingers AND it puts the screws in uniformly.
Patrick
   / hanging drywall #8
I agree their fast - Hard to find (very busy in Central PA) - Here's a idea I'll use to find the studs in my house - If your building a new house or adding on give it a try. Take Pictures of everything - Digging for septic system - foundation - ceiling/studwork in every room (might want to identify which room it is) - wiring - in a word EVERYTHING - Digital pictures are free except for your time and hard drive space and you'll have them for a lifetime.
One thing I did do was stay out of the worker's way. Nights and weekends./w3tcompact/icons/crazy.gif I probably took over a 1000./w3tcompact/icons/shocked.gif
   / hanging drywall #9
Is that the same as/similar to the new decking guns they have out? Last time I went to get a box of screws, seems like the belt fed screws were exremely expensive. Did I miss out or misread something?
   / hanging drywall #10
i agree on the taking pictures suggestion, i've gotten myself out of a couple binds when the memory just wasn't there..i was wondering, from the picture you posted, it appears the house is on a crawl space??? why do plumbers always put the p-trap in the wall, instead of under the house??
heehaw
Payment Terms (MUST READ) (A50775)
Payment Terms...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2017 Ford F750 Buck Truck (A52377)
2017 Ford F750...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
