Halloween Special - Kill Booby Death Trap with Backhoe
   / Halloween Special - Kill Booby Death Trap with Backhoe #1
Metsaman
Europe / Finland
Massey Ferguson
I know that You allready have last weekend Halloween but here in Europe it is this weekend... made Halloween Special video.. :eek:
   / Halloween Special - Kill Booby Death Trap with Backhoe #2
Wow, that didn't take much at all to tip it back. Could have flattened someone like a pancake. Nice video! :thumbsup:
Thank You, it was surprisingly easy job.. :)
   / Halloween Special - Kill Booby Death Trap with Backhoe #4
I've got about half a dozen cherry trees with rootballs similar to that, but a lot deeper holes and less wide as yours. I've left the trees on them for now, but the plan for me is to use the FEL to fill in the holes before I cut them off so there's no place for them to tip back into. You can't do that so easily with your rocky terrain. Ours is all sand and gravel.
   / Halloween Special - Kill Booby Death Trap with Backhoe #5
Sure were clean looking rocks under that tree when the roots took up all the soil. Very nice safety video.
I'm surprised that one didn't topple back on its own when the tree truck was cut off the roots. THAT can be another death trap.
Yes here is lots of rocks and usually those thumps tip back by it self.. but this one doesn't...
   / Halloween Special - Kill Booby Death Trap with Backhoe #7
Great work! Was it to tight to get to it with your big tractor?
If you had stacked a couple of pumpkins under your death trap before tipping it over....That could have been cool.
Thank You, yes it is possible to get stump on Your neck when You cut off log.. danger and only way is watch carefully stump movements when You start to cut log off..
Thank You, that terrain around on stump is quite hard and very narrow lines so I decided use My backhoe for this... that pumpkin idea... I have to make it sometimes in future.. Thanks.. :cool:;)
   / Halloween Special - Kill Booby Death Trap with Backhoe #10
I had about 8-9 oak root balls like that in my friends woods. They weren't quite as tall but had more dirt on it. I read a couple stories of kids getting crushed by playing in those holes when the root ball falls back when the stump is cut. I cut them off when I knew nobody was around and it dropped with a big thud force was incredible.
I never saw one fall back towards the direction of the tree and probably was careless in that regard. I should have had the FEL against it to keep from falling toward the tree.
2006 Poly-Coat Tanker Trailer (TITLE) (A50774)
2006 Poly-Coat...
2018 FORD F-150 XL CREW CAB (A51406)
2018 FORD F-150 XL...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2025 12V Diesel Pump and Hose with Meter (A50323)
2025 12V Diesel...
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
