Hahn snowblower
   / Hahn snowblower #1
dp5069
western Wisconsin
wheelhorses 702 503 854 L-157 CHARGER-9 CHARGER V8 C- 81 1948 8N FORD
I have an old hahn chain driven sunstrand rearend snowblower. The problem is it goes forward ok, but in reverse the chain starts to bunch up and binds, throwing the chain off the gear. The gears seem to be alined up with each other! Could the chain be sprung? thank you Dan
   / Hahn snowblower #2
Dan,
Have you checked the chain to see if it is loose? Over time the chain will stretch and needs to be adjusted. Also you may have a chain tensioner that is broken and not keeping the chain tight.
LOL
Doug
   / Hahn snowblower
Doug, thanks for the reply. In fact the chain was so loose that the chain tensioner could not take up all the slak. I took a couple links out. it seems to stay on the gears better when its a little loose. however like I said it stays on going foward but binds up going backwards. I think at onetime it bound up and sprung the chain Im going to try replacing whith a new one.
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2007 Dodge 3500, 6.7 Cummins, Automatic (A52384)
2007 Dodge 3500...
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
