Had her on 3 legs the other day
   / Had her on 3 legs the other day #1
CT230 Fan
Stewartsville, MO
Bobcat CT230
I think I will be getting my tires filled in the near future. The other day, my brother in-law asked if I'd bring my CT230 over to move some lime that he had delivered for his new dog pins. So I was digging in getting heaping buckets full of lime. I was impressed with her lifting capacity. I took a bite that had a bit more on the left side than the right, and had the bucket a little higher than I should have. I was backing up a slight incline at an angle, and my right rear wheel came off the ground. Took me a second to figure out what was happening. Needless to say, I dropped the bucket, dumped the load, and took small loads from that point forward. Normally I have my finish mower or brush hog on the back for counterbalance, but since I was hauling the tractor, I didn't bother taking them.
I talked to the local Rimguard dealer, and I can get my GP rears(15-19.5) filled for $174.00 and add a total of 620lbs to the rear of the tractor. I think this will be a help.
To be honest, I was on the fence about loading the tires before, but I have decided it is the thing to do. I just hope I don't leave a larger or deeper foot print when I am mowing the yard.
   / Had her on 3 legs the other day #2
Maybe only half fill the tires? That would help lower your center of gravity significantly (help with the left-to-right roll prevention, without adding as much weight. But it wouldn't help from picking up the rear as much as fully loaded tires.
I mow with my CK 122 and can't imagine filling the rear tires, it seems to leave light ruts as it is in semi-moist ground.
   / Had her on 3 legs the other day #3
The equivalent Kioti tractor requires 700lbs attached to the 3-pt hitch as proper ballast for it's loader so 620lbs in the tires which is further forward then the 3-pt hitch is still not as much as they feel fit.
I loaded my tires since I had no plans on mowing with it but in your case I would recommend something removable such as a large bucket of concrete or a box blade with weights that you can take off when mowing.
   / Had her on 3 legs the other day #4
I loaded the tires on my 440. It made a huge difference in pushing and pulling. But I was trying to pick up the end of a huge oak tree trunk so I could wrap a chain around it. I picked it up about a foot and one of the rears came right off the ground. And this is with those huge tires filled with water. I was impressed!
   / Had her on 3 legs the other day #5
CT230,
If you mow your yard with it, I would advise against loading your tires. This tractor is already heavy.
I have not done it yet but if you or you know someone that is good with metal you could make a 3pt ballast. I plan on taking a 55 gal drum and filling it with sand and build a metal cage around it to attach to the 3-point.
It will be easy to take off when I am not using it and I can always add or remove sand iff needed. I have not done the calculations yet but I think I should be able to get 600-700lbs out of it.
   / Had her on 3 legs the other day #6
I have loaded tires in my ck30 no problem in dry weather leaving tracks, wet is a different story, but I don't do much in wet weather anyway.
   / Had her on 3 legs the other day #7
I just loaded My rears on my Antonio Carraro ttr4400 last month. before I could go on a ten degree slope with my hedge mower fully extended and now I have pushed it to 20-25 degrees without any worries. I used enviro freindly plumbing antifreeze. was only $1.45 a gallon and good to 55 below.
2022 CATERPILLAR 317 EXCAVATOR (A51246)
2022 CATERPILLAR...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53472)
GALAXY - SET OF...
