I was bush hogging this past weekend with my recently repaired cutter and started feeling a vibration, it felt nothing like the heavy wobble before the repair I posted about before. I stopped and started the cutter a few times to verify that it was coming from the cutter and finally picked it up and headed back to the pole shed to give it a good look. I didn't notice it at first because the resistance from the very high grass was enough to keep it pulled back into position, but as soon as I got back on to the main lawn, the whole cutter swung over and was about an inch from rubbing the left tire.
Finally got to where I could check it out, it was a simple fix, but vines had jerked the keeper pin out of the tractor side of the left 3 point hitch lift arm. The arm had came off the pin and the weight of the cutter had it pushed way up under the tractor.
I had a distinctly sick on my stomach feeling thinking at first I had tore up my beautiful tractor. I felt much better when I saw how simple the problem was. /forums/images/graemlins/grin.gif
