Haban 54" snow/dirt blade
   / Haban 54" snow/dirt blade #1
rsheetz
Rising Sun,Md
Cub 1572
I'm trying to find specs for the hyd. cylinder for the angle feature on this blade,a friend has a hydralic shop and has many used hyd. cykinders and says he most likely has one that will fit it (trying to save a few bucks).
I basicly need the length,ram dia.ram travel and mounting configuration,mine uses ain through each end.
All help and coments are appiciated.
Thanks!:cool2:
   / Haban 54" snow/dirt blade #2
I would use at least a 3 or 4 in cyl.
You could use many different cyl, just place the cyl mounting points for the cyl to use the full stroke of the cyl.
   / Haban 54" snow/dirt blade #3
Just get you some snowplow cyls, they are SA and you well need 2. Your buddy can help you with the cross over plumbing. I have seen them for as low as $50.
Thanks for the promt answers,now I have a place to start............and now I need a recitifier for the 1572............some days it don't pay to get outa bed:shocked:
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
Utility Trailer (A52377)
Utility Trailer...
24FT Enclosed Trailer (A53424)
24FT Enclosed...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2018 JLG G9-43A (A47477)
2018 JLG G9-43A...
