GX345 Carb- Get JD part or Kawasaki part?
   / GX345 Carb- Get JD part or Kawasaki part? #1
Basstronics
Millbury, OH
2002 JD GX345
Im having a fuel issue and have it narrowed down to the carb. I do not have the expertise or patience to do a carb rebuild with the small parts. Looking to buy a new carb.
JD part is $210 bucks. Kawasaki part is $118.
Im told the only difference is one has the shutoff solenoid which would help prevent backfires when I shut off the engine. Is it porrible to buy the cheaper carb and just remove the bolt on the bottom and add my solenoid? Just bout a replacement solenoid thinking it was the problem- hate to pay for iot again on a new carb.
Anyone use the carb with just a bolt?
John Deere Carburetor Kawasaki GX 345 FD611V AM131756 | eBay
Genuine OEM Kawasaki CARBURETOR-ASSY [KAW][153-2347]
   / GX345 Carb- Get JD part or Kawasaki part? #2
I've heard when the solenoid fails you can grind down the pin and get your tractor running, but no longer have the anti backfire feature. I would buy the Kawasaki carb and try it as is.
   / GX345 Carb- Get JD part or Kawasaki part? #3
Genuine OEM Kawasaki CARBURETOR-ASSY [KAW][15��3-2347]
Did you end up trying this carb..? Did it work..?
I'm in a similar boat.
   / GX345 Carb- Get JD part or Kawasaki part? #4
Most times the Deere part comes in a Kawasaki box with a parts sticker over it. Deere certainly doesn't make them. If you source the right carb and can save $$ , go for it. The anti backfire solenoid isn't worth worrying about.
2015 Kia Sportage LX SUV (A50860)
2015 Kia Sportage...
1996 Stoughton Semi-Van Trailer (A50860)
1996 Stoughton...
2017 KOMATSU PC228USLC-10 EXCAVATOR (A51242)
2017 KOMATSU...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
1999 Ford F-150 Pickup Truck (A48081)
1999 Ford F-150...
Kobelco SK200SR LC Excavator (A50860)
Kobelco SK200SR LC...
