Gully through the property
   / Gully through the property #1
fishdoggy
Southern WI
IH 240, IH TD 9, Kioti DK 45
I am purchasing 20 acres of wooded hillside that has a building site but it is 200 feet from a gully. The gully is not more than 10 feet at the widest spot and not more than 6 feet at the deepest and no running water in it. It may have formed 40 years ago and will not get worse for another 40 years. What kind of options are there for something like this?
   / Gully through the property #2
I would be asking myself what made that gully. If it was running water then for sure don't fill up the gully because the next time water comes through there it will have to find a new channel - somewhere you may not want it!
   / Gully through the property #3
The issue with a gully is that if you fill it, the soil will be softer then the surrounding soil, so it will wash away when you get a heavy rain.
In order to stop this, you need something in there to hold the soil in place. Busted up concrete works great for this. It slows down the water and allows the soil to build up behind it.
Depending on the length of the ditch, you should build up several "dams" of broken up concrete or large rocks to hold the dirt in place and slow down the water.
On my land, I also use used and broken bricks, cinder blocks and even tile from jobs that I've worked on. I just keep building it up until I'm at the height of the surrounding soil. Most of the time I don't even need to add dirt, it just starts filling up on its own.
Asking about options, I like the several dams in it to slow down the water and fill in with the runoff soil over time.
   / Gully through the property #6
Search and analyze flood water plains in that area. Ask some neighbors who must have the same ditch when and how much water they have seen in it.
   / Gully through the property #7
Your asking for options but you have no intention or goal stated, you have stated facts without issues... so I read this and I don't know what kind of options I should suggest.... just trying to make it clear for me and everyone else to properly help you.
   / Gully through the property #8
I would make it a "feature". It's there by some cause. Perhaps runoff from a higher elevation or a long-ago rift. I would use the feature to protect other parts of the property. I have a natural "gully" that runs about 7-800 feet along the back and western boundary. It turns out to be a good drainage diversion off the property behind me and into the property to the west. I was glad to have it when we got 8-10" of rain from a hurricane years ago. I got my tractor stuck in the mud in it weeks after. I had to get the dozer to pull it out. I don't do much mowing in that area anymore. It's pretty wild and a good habitat for wildlife.
Perhaps as you say, a few rock dams to slow erosion and provide temporary watering holes.
My goal is to not let it get worse, have thought about ranchers that capture water for cattle, then pump it where the cattle are. No plans for that, but I have seen the ponds they create for that.
   / Gully through the property #10
The amount of water running through the ditch doesn't really matter. What creates ditches, and makes them hard to fill is the speed that the water is going.
Slow it down and the erosion will slow down. Eventually you should be able to get it to the point that it's all flat and grass will protect the soil.
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
7046 (A50322)
7046 (A50322)
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
ASSET DESCRIPTIONS & CONDITION (A51219)
ASSET DESCRIPTIONS...
2008 Ford F-350 4x4 Pickup Truck (A50323)
2008 Ford F-350...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
