Guidance on how to rebuild this steering cylinder??
   / Guidance on how to rebuild this steering cylinder?? #1
Richard
Elite Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I've got this JCB. Looks like I might need to redo the steering cylinder. Fine. Done some others so this won't be an issue......except, there is some "wire" that is curled in there (see picture).
Anyone ever do something like this? None of my other cylinders have this wire so I don't know what to expect. (maybe nothing!!)
Any issues or tricks on taking it out correctly/easily?
How about replacing it correctly/easily??
  • Cylinder.pdf
Regarding replacement, the replacement kit shows the new wire to be STRAIGHT, not curved.... how does it get properly bent?
   / Guidance on how to rebuild this steering cylinder?? #3
You need to rotate the gland till you can see the little tab of the wire though a small hole. Then you try to pull the wire while you also rotate the gland.
Yes, the new wire will get bent once in place.
Check this video at around the 14:00 mark:
UNUSED AGT YSRT14 STAND ON SKID STEER (A51243)
UNUSED AGT YSRT14...
TAKEUCHI TB2150 EXCAVATOR (A51242)
TAKEUCHI TB2150...
2015 JCB 930 6,000LB 4x4 Rough Terrain Forklift (A50322)
2015 JCB 930...
Westendorf Gravity Wagon (A50514)
Westendorf Gravity...
2019 KOMATSU PC290LC-11 EXCAVATOR (A51242)
2019 KOMATSU...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
