GT275 Problems
   / GT275 Problems #1
sunsethill4
John Deere gt275
I have a 10 year old GT275 that has been terrific and a few problems have popped up that need to be fixed. I am starting to tear into it and need some advice. Since all the problems have something to do with the operation, I will include them in this post in hopes of getting some problem solving tips.
1) I have an oil leak that seems to be originating from around the valve cover (or other seal on the front of the engine) and pools oil on the muffler while sitting. It burns off and I am good to go after about 5 minutes of running. Should I replace the valve cover gasket?
2) I have trouble starting when turning the key and it usually takes about 5-10 tries until it starts. Is it the ignition key switch?
3) The hood plastic piece is broken and I did review the other posts on this subject but wondered if there was other advice for bonding that may not have been included.
Thanks for taking the time to read over this post and offer advice.
   / GT275 Problems #2
I have a gt 235. A couple of years ago it got to where it would just click several times before actually starting. It turned out to be the starter solenoid. As to the hood I have fixed mine in several spots using two part plastic expoxy and scrap pieces of plastic on the under side. The key is to rough up both surfaces. I used an angle grinder.
   / GT275 Problems
Thanks buck12. I am going to replace the starter solenoid.
3014 (A50657)
3014 (A50657)
2006 Ford F-150 Pickup Truck (A50860)
2006 Ford F-150...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A48081)
2022 Chevrolet...
2022 J&M 1151-22S Classic Grain Storm Grain Cart (A50657)
2022 J&M 1151-22S...
2018 Nissan Versa SV Sedan (A48082)
2018 Nissan Versa...
2015 Jeep Patriot Sport SUV (A48082)
2015 Jeep Patriot...
