GT2550 Won't Start
   / GT2550 Won't Start #1
rau2009sch
Monett, MO.
Cub Cadet GT 2550
Have GT2550 with 45 hours on it, went to start it, ran rough, now it won't even start. Spins over plenty fast, but no start.
Getting plenty of gas, in fact it runs out the muffler.
Has full warranty, but Ihate to haul it in the pick-up back to dealer.
Any ideas?? thanks.
   / GT2550 Won't Start #2
fiirst off, would pull and smell residual oil on crankcase dipstick for the possible presence of raw fuel mixed into crankcase oil. If you do smell fuel, do not run engine until you have drained old crankcase oil, replaced engine oil filter, replenished crankcase oil and repaired flooding carb.
Raw fuel in crankcase oil will substantially reduce the oil's lubricating properties, allowing serious engine wear/damage.
As a number of different defects can cause your described problem, suggest you get that machine back in for warranty repair quickly.
   / GT2550 Won't Start #3
...and it couldn't hurt to carefully observe that the linkage for the hand choke is correctly working too.
btw, our 2550 just turned 700 hrs and I've really come to appreciate this machine.
   / GT2550 Won't Start #4
With that much fuel, the only other place to look is ignition. You advise the engine is spinning over so the "Safety Interlocks" are not malfunctioning. If it is a Kohler engine, Kohler usually uses a white wire to ground the coils. Remove the plugs, attach a spark plug wire to one of the plugs and then use a pair of vise grips to hold the plug to a metal ground. I use a piece of covered wire, attach one end to a good ground on the mower (ground post on battery) and then attach the other end to the spark plug with he vise grips. Used to just hold the ignition cable. Some of the mowers today put out quite a wallop. Spin the engine over any spark at the gap on the spark plug?
No spark check and see if you can see a white wire coming out of the covering on the engine. Trace the wire to a point where you can disconnect and see if the engine will starts. If the engine starts you will have to ground the white wire to stop it.
The ignition switch could also be shorting the start circuit to ground when turned to the start position.
Turn the ignition switch to the on position and jump the solenoid at the starter and see if the engine will start.
If the coils have gone bad, call the dealer. Removing the sheet metal to get to the coils can become rather involved.
While you have the plugs out, do the thumb test. Place your thumb or other finger in the spark plug hole and spin the engine over. Got good compression, blow out and suck in on each cylinder? If not you have a valve train problem.
2013 Freightliner M2 106 Medium Duty Truck, VIN # 1FVDCYDT3DHFF4784 (A48836)
2013 Freightliner...
2019 John Deere 317G Track Loader (A50490)
2019 John Deere...
3 Point Hitch and Set of Rippers (A48837)
3 Point Hitch and...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A50458)
2019 CATERPILLAR...
2019 JOHN DEERE 644K WHEEL LOADER (A50458)
2019 JOHN DEERE...
UNUSED KJ 45' X 25' DBL GARAGE STEEL BARN SHED (A50460)
UNUSED KJ 45' X...
