GT2500 carb/linkage help
   / GT2500 carb/linkage help #1
byronjackson012
Alabama
2005 lt 1046/2006 GT2550/Yanmar ym226d with FEL/Cub Cadet Z-force Fab 48
I'm pretty sure i've seen post on this same subject before it happened to me. Here's the deal:
Tractor operates fine when squeky clean and lubricated but after an hour or two of use, throttle either
A. sticks high (won't idle down)
B. sticks low (won't throttle up)
C. Idles low when throttle is high then corrects under load (PTO engages)
I've looked at the linkage and everything seems to be in place and moving. It appears that the force required to adjust carb/governor is not provided by throttle position/spring tension. Any help would be greatly appreciated.
   / GT2500 carb/linkage help #2
The first thing I did when I got mine home was to spray the linkage with a lubricant and then cover that with spray lithium grease. Hopefully I may not have the same thing happen ????
This is the first I have heard of this(but then again I haven't been around here all that much before about 3 weeks ago).
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
Electric Mobility Scooter (A51694)
Electric Mobility...
2018 INTERNATIONAL LT625 (A53843)
2018 INTERNATIONAL...
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A51692)
2018 Ford F-250...
2016 Arising 8.520VTRW 22ft T/A Enclosed Cargo Trailer (A51694)
2016 Arising...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
