GT245 power flow bagger ?
   / GT245 power flow bagger ? #1
Rebs
Bronze Member
Niagara Falls, NY
JD 175
Will a power flow bagger off a GT245 fit on a GX345 tractor ?
   / GT245 power flow bagger ? #2
I don't know if it will work or not but when I was installing my power flow set up the deck was the issue. Point is compare the decks to get an idea of what will fit and see if JD parts has a break down for the deck in question. Make sure you can add the proper drive pulley too. It has been a couple of years since I did this but I do remember having to trim some of the flange to properly fit it to the deck.
Toro Z Turn (A50322)
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2020 Kinze 3505 High Speed 6/11 Planter (A52128)
2020 Kinze 3505...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
Toro Zero Turn Mower (A50322)
Toro Zero Turn...
2004 Ford F250 (A50515)
2004 Ford F250...
