GT245 Mower Deck Clutch
   / GT245 Mower Deck Clutch #1
stevegay
Hernando, Ms
2003 New Holland TC29D
The deck clutch has been failing to engage intermittently. It failed yesterday and I couldn't get it function properly again. I have tested yellow switch at the connector to the clutch. With a meter on ohms, the open circuit will change to 0 ohms when the switch in pulled up (energizing the clutch) then quickly increases and settles at 127 ohms. I applied 12 volts directly to the clutch, bypassing the switch and the clutch doesn't engage. All of the testing I've done indicates the clutch is bad but I wanted to check here to make sure I'm not overlooking something or this clutch works differently than I'm expecting before buying a new clutch.
   / GT245 Mower Deck Clutch #2
This sentence does not make sense. Do you mean that you checked the PTO switch?
You should not be measuring voltage with the meter in the ohms position.
Do you have the owners manual?
There should be some trouble shooting guides in it.
Richard
I tested the yellow PTO switch to see if it was working so I was looking for continuity when I pulled up on the switch. That's why I had the meter set for ohms. I followed the wires from the PTO switch down to 2 wire connector near the clutch and disconnected it there. I wanted to make sure the wiring was good as far down the circuit as I could get. I wasn't checking for voltage at the clutch as I would have to crank the mower and sit on the seat and I cant do that and test the circuit. Instead, I applied 12 volts directly from the batter to the clutch and the clutch did not engage. I do not have a manual. The mower was donated to my church many years ago. I can search for a manual but I thought someone may have some experience with this exact problem and could offer some advice.
   / GT245 Mower Deck Clutch #4
If you are putting 12 VDC on one clutch terminal and grounding the other, if the clutch is good it will fire.
   / GT245 Mower Deck Clutch #5
Did you check resistance or ohms on the PTO clutch when you had the wires disconnected? I recently fixed a neighbor’s mower that had a broken wire by the clutch that would randomly work then finally quit completely. It was a broken wire in the harness to the clutch. I found this by checking continuity and wiggling wires.
1261 (A50490)
1261 (A50490)
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
2022 ELITE 102" X 40' GOOSENECK TRAILER (A50459)
2022 ELITE 102" X...
2022 J&M 1151-22S Classic Grain Storm Grain Cart (A50657)
2022 J&M 1151-22S...
2014 GOOSENECK DRIVER SIMULATOR TRAILER (A50854)
2014 GOOSENECK...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
