gt245 hood cracked
   / gt245 hood cracked #1
jimbo64
see about an 8 inch crack in my hood on my gt245- Normal usage-600 hrs and bought new in 2002-made a temp repair and then lined it with weather
stripping to dampen the vibration-------anyone else had this prob:mad:
   / gt245 hood cracked #2
Only saw it once when someone was sitting on it and riding. Kids do the darndest things.
   / gt245 hood cracked #3
I have a gt 235 and have repaired the hood a couple of times. I used two part plastic glue to attach plastic strips to the underside of the hood. The repaired areas have held up well and I am now more careful with the flimsy hood.
   / gt245 hood cracked #4
A lot if hoods are cracked from allowing the hood to fall from full open to closed position. At least that's what I was told, so I baby the hood when opening and closing.
   / gt245 hood cracked #5
You are correct. Another common place for the hood to crack is where you open it, the hand slot. It is best to reach over the and use both hands with a hand on each side of the hood.
well no one has ever ridden on it and it has never been dropped down to my knowledge,just a weak design i would guess-repair works, but this thing cost enough didn't think i would have a cracked hood- weather stripping around the under edge will prevent it though- wish i had put this on before----everyone should consider this
2014 FORD F-150 (A45046)
2014 FORD F-150...
2019 Ford F-150 (A41519)
2019 Ford F-150...
WITTIG VACUUM PUMP (A45046)
WITTIG VACUUM PUMP...
2018 International HX620 6x4  Heavy Axle Truck (A42203)
2018 International...
1978 LUFKIN TRAILER (A45046)
1978 LUFKIN...
2014 WESTERN STAR 4900 SF (A45333)
2014 WESTERN STAR...
