GT235 suitcase weights
   / GT235 suitcase weights #1
buckbros
Bronze Member
Maryland
john deere LT180, John Deere GT235, 1950 Case Vac, 2 Gravely L Models
Does anyone know if a R66949 suitcase weight will fit a GT235?
   / GT235 suitcase weights #2
Front or rear?
For the front, get the BM19511 front weight bracket.
Front or rear?
It would be for the front. Mine has a brush guard on it now. I assume that would have to be removed???
Likely.. if they won't hang off the brush guard..
Sample pic
John Deere Front Weight Bracket/Bumper - BM19511
Thanks for the replies. I mow 2 acres of mnt. ground with some hills & banks around some trees.. The front end wants to come up if I am going up a bank & try to turn the front wheels to go around the tree.. I guess I'll just have to put up with it as I am not putting that much in the brkt. & weights.
   / GT235 suitcase weights #6
What do you have on the back that is heavy enough to make the front end light?
There is nothing on the back of the tractor. That is what confuses me. I bought this tractor used after my LT180 started having tranny problems. The LT 180 never lifted up on the front end like the GT235 does. I thought it may be from the heavier tranny on the GT235. The banks I am mowing are pretty steep. Probably why the LT180 tranny gave me trouble.
2021 Caterpillar 299D3XE Track Loader (A53342)
2021 Caterpillar...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
INOP/NON-RUNNING 1999 International F-2574 Fuel Lube Truck, VIN # 1HTGGATT4XH682675 (A51572)
INOP/NON-RUNNING...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
