gt1554 toe out
   / gt1554 toe out #1
cub74
cu cadet gt 1554
Having a problem with the steering on the tractor. Went through a ditch and then tractor steering toed out. Replaced tie rods and no change. Tractor steers hard now. Nothing else looks bent. Any ideas? Thanks
   / gt1554 toe out #2
Here's the alignment procedure for the 1000/1500 series.
   / gt1554 toe out #3
Almost every vehicle requires toe "IN". Toe out creates problems. If you have about 1/8" toe in that should be pretty close to correct.
Hard steering after that is correct means something else is bent or broken. Look the whole front end over for anything that does not look right. Even tire pressure will cause hard steering.
2022 Club Car...
2020 Peterbilt 579 Daycab Truck Tractor (A50860)
2020 Peterbilt 579...
2019 RBR Venturi 380 (A50397)
2019 RBR Venturi...
2006 Chevrolet 3500 Express Enclosed Service Van (A48081)
2006 Chevrolet...
2008 HINO 268 ARMORED TRUCK (A50505)
2008 HINO 268...
2017 Chevrolet Silverado 3500 HD 4x4 Crew Cab Reading Service Truck (A48081)
2017 Chevrolet...
