GT14 restore turning into nightmare...
   / GT14 restore turning into nightmare... #1
86turbodsl
Bronze Member
Albion, MI
Yanmar GT14, Oliver Super 55
Well, I found out why the end of the crankshaft is bent. When I took the front pto unit off, then the radiator, I found the pto mount was cracked, and part of the mounting flange had been cut away. I wondered why, until I got a look at the pto unit. The stub shaft that enters it was spot welded on, and the splines in the pto unit were stripped. I found the stub shaft was bent, and the u-joints were welded in place. This puzzled me until I realized what happened. At some point, either the bolts retaining the pto loosened, causing the mount to crack and finally the pto unit to be ripped out, or the mount cracked, loosening the bolts and allowing the pto to be ripped out. Either way, there's a lot of damage. Also explains why the shroud was damaged in that area. 2+2 = 4. Note to self: There's no such thing as a free lunch. You get what you pay for, yadda yadda... My sub-$1000 mower is turning into a sub-$2000 mower, minus my time which I throw away. It'll be a nice mower, if I ever get it done....
I spent tonight welding in a nice beefy pto mount. 2.5x2.5x0.25 angle iron to replace the formed angle that was there. A bit beefier. Now on to a pto unit rebuild. At least half of the thing needs to be replaced.
   / GT14 restore turning into nightmare... #2
Hey 86,
I can help you with that front PTO situation, I rebuild about two of those a month. Have everything in stock. Also there is a H.D. motor mount kit you might want to consider putting on.
The new front PTO parts are heavier duty than the originals too. Contact me: gandgjamieson@direcway.com
Got the wife's car out of the shop finally, so I rolled the GT over into the
center of the shop and put it up on jackstands so I could pull wheels off for repaint while I'm waiting for more parts. I decided to change the transaxle fluid while it's all apart. The capacity of the sump is 1.5 gallons or so. So I pull the drain plugs and get 6 quarts of fluid and 1 quart of water out! It's a wonder the danged thing even moved. And the surprises just keep ooooon comin....
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
UNUSED FUTURE FT13CJ EXCAVATOR (A51247)
UNUSED FUTURE...
2016 WACKER NEUSON LTV6 PORTABLE LIGHT TOWER (A51247)
2016 WACKER NEUSON...
434669 (A48836)
434669 (A48836)
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
