GT14 not pulling fuel
   / GT14 not pulling fuel #1
kzack
Homer City, Pennsylvania U.S.A.
2210D
Hi, just picked up a GT14 at an auction. Pretty nice condition with 700 hours. It does not run and seems to've been sitting for some time.
Fuel will not flow at all if the fuel cap is tight on the tank. If the cap is loosened, fuel will flow nicely to the low point in the line which is along the frame rail. It will not flow up to the injection pump. If I crank the engine, it will not pull fuel up to the injection pump, whether I have the bleed screw loosened or not.
How exactly does this model pump fuel? Is it exclusively from the injection pump? Does it have a mechanical lift pump? A manual priming pump?
Any advice, much appreciated.
Keith
   / GT14 not pulling fuel #2
It's working as it should. That cap vents through the cap. If you look in the rubber gasket there is a little rubber slot that allows air into the tank. If you crank that cap down like your baton ing down the hatch on a submarine it won't pull fuel. Of course the cap gasket may be gone? Post a pic but sounds like it works as it should.
There is no lift pump and the injector pump is gravity fed , it does not "suck" fuel from tank.
I see grooves cut in the threads of the cap and grooves cut in the threads of the tank. I guess that is what allows it to vent and that makes sense. But I do not under stand how it can gravity feed itself all the way to the injection pump. The tank sits under the seat and the injection pump is definitely higher than that at the engine.
On my 2210d, the tank sits under the hood, but higher than the injection pump.
Thanks, Keith
Yes, I've had to bleed the fuel system on my 2210 and other diesel engines numerous times. But looking this GT14 over in more detail, I've found a cut electric line down by the mower deck and what I thought was a fuel filter on the frame rail, is apparently an electric fuel pump. This makes sense as it is the low point of the fuel line. I don't know if this is factory or previous owner butcher. Either way, I'll have to try and get this all wired back up and maybe a new pump. Hopefully it will then work.
Thanks, Keith
   / GT14 not pulling fuel #6
The GT14 and YM146 have an electric fuel pump at the low point in the line, on the right hand side of the engine just below the frame
It apparently is not working. Check for a blown fuse and then test the pump to see if it is bad.
New ones are available or I have used ones.
   / GT14 not pulling fuel #7
You should post more often, Gary. We occasionally read about you coming up with hard-to-find parts for someone but very seldom hear from you.
   / GT14 not pulling fuel #8
I am wrong. I first read this as on of out old YM tractors. later saw it was a GT tractor and just assumed it was gravity fed like the other older ones. I am sorry.
   / GT14 not pulling fuel #9
We all make mistakes, I make more than most. :ashamed:
   / GT14 not pulling fuel #10
Yep they have an electric lift pump. They are in line with the chassis just infront of your right foot. It does sound like yours has an issue.
2016 Nissan Pathfinder SUV (A50324)
2016 Nissan...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
