GT1045 Blows Fuse
   / GT1045 Blows Fuse #1
jerry1980
ocala fl
cub cadet gt1045
The fuse next to the battery blows after about 5 seconds of running. The fuse will not blow unless the mower is running. Using a Power Probe which has a 15A circut breaker and can be used to apply power to the circut , while monitoring the volt meter on the probe it goes over 15 volts when the breaker trips. It appears to me the charging voltage is too high??I put a new (aftermarket) voltage regulator on it and the problem still exist. If I unplug the regulator the mower continues to run and the fuse doesnt blow. Any ideas or common issues?
Thanks Jerry
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
2013 Isuzu NPR Eco Max Box Truck (A47384)
2013 Isuzu NPR Eco...
CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
CATERPILLAR D3K2...
2003 STERLING ACTERRA ROLLBACK (A51222)
2003 STERLING...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
