GT series difficulty/ease of attaching snowblower
   / GT series difficulty/ease of attaching snowblower #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
I may have an opportunity to sell my GT235 w/ 48"-C deck and buy a similar GT235 with 54" deck/powerflow and snowblower. However, I hear the GT series snowblower is a beast to install/remove.
Anyone have any experiences they can share?
   / GT series difficulty/ease of attaching snowblower #3
I wouldn't say it's a beast,
it slides under the tractor, a couple "C" clips hold it
underneath, (once the right bushings are there) and then
a couple lift yokes hold up the front, with a few pieces to complete
the install, including routing the belt around the pto clutch pulley.
   / GT series difficulty/ease of attaching snowblower #5
15-20 minutes if you don't remember what you did the last time (and forgetting when one only puts it on once a year is prolly normal :D ).
Thinking it through using regular/normal mechanical skills should not present any installation problems. Making some notes of things that should happen first, as well as leaving clips and brackets together also helps. Can be a wonderment if someone else took it off and dismantled everything - been there, done that. :) Makes one think something might be missing.
   / GT series difficulty/ease of attaching snowblower #7
I have a GT225. It takes about 20 minutes to take off the mower and throw the blower on provided you don't miss any steps. The longest part is hooking up the front lift (mine has a hand lift).
I also have a 325 with hydraulic lift. You can have the deck off and the mower on in 5 minutes flat, so the GT is strictly a mowing machine now.
2012 John Deere 850K Crawler Tractor Dozer (A52377)
2012 John Deere...
2010 American LaFrance Condor MRL Long Line Tri-Axle Thermoplastic Striping Truck (A52377)
2010 American...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
