GT 2544 PTO Problem
   / GT 2544 PTO Problem #1
95fxdl
The pto on my 2544 slips when under a heavy load. Are they repairable or do you replace? Where is the best place to buy? Thanks, Dennis
   / GT 2544 PTO Problem #3
Could it be that your belt is slipping? You hear a squealing noise?
+If it's your belt that slipping there's a few things an operator can do. firstly slow down with your ground speed while staying with max RPM's.
+The grass is too tall and wet so cut higher.
+Sometimes in the Spring when things are wet I get behind in cutting so I have to take half a bite of uncut grass.
+Also having a clean under-deck with greased pulleys helps with a more efficient cut.
On the other hand I replaced a few belts that were slipping and wondered what I could do to refurbish them...like in using belt dressing or something. Another poster sparked a hail mary type of idea. So I soaked the belt overnight in the doggie pool and cleaned it with Ajax and one of those 3M abrasive green cloths and gave it a couple of days to dry out. Well that took the glassy like slipperiness off the used belt and kind of restored the grip somewhat.
I've been using that belt with good results but at about the time I restored it and put it one the dry spell hit and as everyone knows dry grass cuts so easy that imo it leaves the belt cleaning exercise in doubt as to it effectiveness. But if all else fails I'd give that a try.
With it engaged and with the hood up, it's the clutch slipping. Also have a new belt installed. Does anyone know if the bolt holding it on is left or right handed? thanks, Dennis
   / GT 2544 PTO Problem #5
Before removing I would pay my Cub Cadet dealer a visit. Find out if the PTO clutch has an adjustable air gap and how to adjust. This may solve your problem. Cub Cadet and the Green machines really love there PTO clutches.
   / GT 2544 PTO Problem #6
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2019 Ford F-250...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52128)
2021 John Deere...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
