GT 2544 Mower Belt Rubbing
   / GT 2544 Mower Belt Rubbing #1
fixercc
Jamestown, NY
Cub Cadet GT2544
Trying to repair a damaged GT 2544 deck. I made a new spindle mounting plate for the right side. No matter where I mock up the spindle, the belt rubs against the deck mounting bracket even with the drive pulley in the locked position. Thanks for the help. Stumped.
   / GT 2544 Mower Belt Rubbing #2
Are you sure you have the belt routed the right way?
   / GT 2544 Mower Belt Rubbing #3
Do you have the PTO-to-deck belt on the drive pulley? Without it pulling the drive pulley forward the deck belt will rub even with the spring arm in the latched position. Drove me nuts looking at it until I just hooked everything up and it magically worked.
   / GT 2544 Mower Belt Rubbing #4
So the side of the belt rubs against your fabed mounting bracket?
One possible option is to take an angle grinder and knock off a few thousandths ...then smooth it with sand paper etc.
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2011 GMC Sierra 4x4 Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
Ford Pickup NR (A50323)
Ford Pickup NR...
378662 (A51573)
378662 (A51573)
