Gt 2186 puking oil
   / Gt 2186 puking oil #1
c3a1r6l
bidwell, ohio
Cub Cadet gt2186
my Gt 2186 with kohler command 20 started puking oil out the valve cover first. I put a new valve cover gasket on it, and it stopped leaking there, but immediately started leaking lower on the motor, possibly around the head gasket. I'm talking major leak. Like
about 1 quart in about 15 seconds of engine running. any ideas would greatly be appreciated
   / Gt 2186 puking oil #2
suspect blown head gasket - blowby pressurizing crankcase...?
I'm afraid it is the head gasket. I don't think they have a pcv valve. Thanks for the help rcbe
   / Gt 2186 puking oil #4
yeah, as my dim memory serves, Commands back a few yrs ago were having some probs with head gaskets - you might do some searching for details.
   / Gt 2186 puking oil #5
Yes, my 2004 Command 25 blew a head gasket. The head bolts appeared to not be torqued down very well. The new kit included new bolts. I assembled the engine minus the shrouds and ran it till hot. I then torqued the bolts a final time and have had no problem the last several years.
Bob B.
   / Gt 2186 puking oil #6
The Kohler Command 20 has a crankcase breather mounted on the crankcase just in front of the carburetor with a rubber hose that attached that vents back into the carb. Check the air filter area is their oil?
Kohler also has posted on their web site service manuals for the Command engine. If you do not have the manual you may want to visit the site and download the PDF file for your engine. It is free.
2009 Champion C80 B Motor Grader (A50322)
2009 Champion C80...
Informational Lot - Shipping (A52748)
Informational Lot...
Harlo HP8500 Forklift (RIDE AND DRIVE) (A50774)
Harlo HP8500...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
2 Axle Trailer (A50774)
2 Axle Trailer...
