Growling vibration in bobcat 863
   / Growling vibration in bobcat 863 #1
Sophiedoc
Missouri
Multiple
Used machine with about 1800 hrs.On using hydraulics for lift,dump or accessory there is a growling sound and vibrations you can feel especially well in the lift cylinders most noticeable @ low rpm.Hydrostatic drive seems OK.Hydraulic pressure on outlets tops 3000psi.We can find no air leaks down to the pump inlet or any blockage.Is there anything other than the pump that could cause this and if the pump is the culprit must it be fixed @ this stage since functioning seems OK.Thanks for any possible insight of the problem.-PS,we have replaced the hydraulic fluid also but no change.
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A52577)
2021 FREIGHTLINER...
City of Buckhannon - 2000 Chevy 2500 (A52384)
City of Buckhannon...
STORAGE FEES (A53426)
2020 JOHN DEERE 331G SKID STEER (A51246)
2020 JOHN DEERE...
