Ground Synchronizing PTO?
   / Ground Synchronizing PTO? #1
CharlieTR
NE TX
Long LongTrac
I was talking (or trying to anyway) to couple of older gentlemen about tractors, and land/cows, etc. The subject of the PTO level came up. One guy said the two position lever was Hi/Lo. I said no, it's Live or Ground sync.
Ground sync will keep the PTO turning at the wheel speed of the tractor. Live the wheels and PTO are independant. The other guy said why, you use the small wheel on the implement to set the speed, he answered every question with a question. I said yes, but that's what the level does. I am not sure if I am using the term Live PTO correctly though.
My question is when would you use the ground synchronizing PTO?
   / Ground Synchronizing PTO? #2
Live PTO is simply where your PTO shaft is driven and controlled by a seperate clutch so it's independent of the transmission.
Ground speed PTO isn't so common anymore. It WAS more common, but still not all that popular back in the mid 50's to mid 70's, primarily on smaller utility tractors. I'm more familiar with Massey Ferguson, who used GSPTO on most of their tractors then. They sold, for instance, a hay rake that was PTO driven. It employed the GSPTO for power. Also, some planters used GSPTO (or so I'm told. Never actually saw one) I would imagine a hay tedder could use GSPTO, but from all I remember, it was one of those "good ideas" that never caught on.
   / Ground Synchronizing PTO? #3
Yes, it was a good idea. We used it to drive fertilizer distributors on cultivators and power tillervators, worked great. Must not have been enough demand for it.
   / Ground Synchronizing PTO? #4
Still used in the European markets to power wagon wheels which enable a smaller tractor to pull a larger load up & down steep hills.
My Zetor tractor can reverse pto - example to unstick a post hole digger.
Low gear is 289 rpm high is 1344 rpm, not something a 540 cutter is going to want to see.
   / Ground Synchronizing PTO? #5
My MF65 has a mounted 2-row corn huskor.. it is run in normal PTO.. but when you get a jam in the huskor.. you put the PTO selection to ground speed.. when you put the tractor in reverse.. the PTO runs in reverse.. this effectively clears out the debri causing the jam.
   / Ground Synchronizing PTO? #6
My Old Massey 135 has the two speed PTO , Never have used the Ground speed option on it...But I'm not a real farmer with alot of equipment either ;)
Thanks for the info, this is interesting.
So I guess most tractors in US market don't have GSPTO?
I seems funny the differences in the controls on my Longtrac 520.
I was at the dealer wanting to trade it in for about 100 HP.
I climbed in a Case 1086 (120 HP) and had no clue what was what on the controls. Then the dealer got on mine, he looked at me funny and said I have no clue what these are for.
   / Ground Synchronizing PTO? #8
Farmtrac 675 dtc has it. Don't know what I'd ever use it for though.
KB
   / Ground Synchronizing PTO? #9
As mentioned some mf tractors have it.
Soundguy
   / Ground Synchronizing PTO? #10
Soundguy
From day one under the MASSEY FERGUSON banner, they featured GSPTO. My 150 has it. I'd bet 98% of the tractors with GSPTO have never actually USED it. In 35 years, I've used mine ONCE to clear a stuck manure spreader. (Put GSPTO in gear, backed up tractor, reversing PTO shaft)
Another good idea that never made the big time.
1996 Trailmobile 53 ft. Dry Van Trailer (A53117)
1996 Trailmobile...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2014 CATERPILLAR 303.5E CR EXCAVATOR (A52706)
2014 CATERPILLAR...
2010 Chevrolet Tahoe SUV (A53424)
2010 Chevrolet...
2010 LONE STAR TRAILER MFG. GOOSENECK TRAILER (A53843)
2010 LONE STAR...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
