Ground Prep For Sod
   / Ground Prep For Sod #1
southern83fire
Virginia
I have a rental property in Virginia that is in serious need of some lawn care. The backyard is nothing but a few patches of grass and weeds. Its a small yard about 400 square feet, so I'm thinking about putting sod. I don't know how I should prepare the ground.
It's about 100% good old Virginia clay. One edge of the fence line has a tree root running above ground from my neighbors tree. Any suggestions about how to prepare the yard would be great. Thanks!
   / Ground Prep For Sod #2
I'm working on this right now. I should have been taking before and during pictures, but haven't been. Lots of seat time. I'm fixing a lot of erosion issues first, so my efforts won't be in vain. That is the primary thing to do. Make sure your drainage issues are correct and you have a plan for any runoff, then prep for sod.
I've cut a swale probably 250 ft long along my property line to catch runoff and direct it to my main drainage ditch. Then I'm redoing the main drainage ditch with my FEL and box blade and fixing a lot of erosion spots and smoothing everything out.
For the sod, I'm getting Bemuda and will start with sodding the main drainage ditch and the side swale and side yard will be seeded and covered with straw matting.
Pictures would help, but to answer your question, you need a smooth surface for the sod. You can round up the existing grass and weeds if you like the lay. The sod comes with top soil. Better option is to lightly till the area before applying the sod and if you have a roller, rolling it one time would help make the contact. The most important part is to water water water after laying it for a good week or more so the roots can take hold. The areas I'm not sodding, but seeding instead (my side property), I'm prepping with putting top soil an inch or two thick and smoothing before seeding, then laying straw mat to control run-off, then watering well also. In my parts, a lot of lime helps and a little starter fertilizer.
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
LOAD OUT AND SHIPPING (A51573)
LOAD OUT AND...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2011 FREIGHTLINER CORNADO (INOPERABLE) (A52472)
2011 FREIGHTLINER...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2008 Wells Cargo T/A Enclosed CERT Trailer (A50324)
2008 Wells Cargo...
