Ground clearance
   / Ground clearance #1
cmkh3
Kitsap County, Washington
John Deere 322
So which makes and models would you consider looking at to get around 13"'s of ground clearance. So far I have looked at Branson 2400H and Mahindra 28xlH which both have ground clearance coupled with a lower price tag.
Best
Chris
   / Ground clearance #3
How big of a tractor are you looking to get?
I just got a Branson 2400H and like it a lot. I could not find any tractor (new or used) that could compete with the price I got.
   / Ground clearance #4
It depends on which tire you get. If you have turfs you will have a lot less clearance, R1 you will have a lot more clearance.
   / Ground clearance
I have looked at and driven 5 tractors. In order of driving only no biases (yet) John Deere 1025r FILB, Kubota BX25D, Mahindra 28xlH TLB, Branson 2400H TLB and Massey GC1720TLB.
The two with the greatest ground clearance were the two with the least creature comforts. That said extra lights and "stuff" get broken too easily for me so... The Massey had a very comfortable seat but to swivel it around for the backhoe requires an engineering degree. The one that I would have liked to test drive is not available until July (Branson 2800 H TLB).
If I had to buy one of the 5 I have test driven it would be the Branson 2400, Most beastly small tractor I have driven for the $.
Best
Chris
   / Ground clearance #6
If the backhoe is mounted to a subframe it takes a lot of your ground clearance away. Just something to keep in mind - specs are often without backhoe.
   / Ground clearance
Is there any consistency between manufacturers for specs if a tractor with a backhoe subframe comes from the manufacturer? For example the John Deere 1025r FILB.
Chris
   / Ground clearance #8
I don't think anyone lists the backhoes ground clearance.
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
