Ground Clearance on BX2200
   / Ground Clearance on BX2200 #1
mthiel
JD 4110
Anyone have any trouble with ground clearance on the BX2200?
I have read many great things about this tractor, but one of negative factors is low ground clearance of 6.7".
When does this become a factor?
   / Ground Clearance on BX2200 #2
<font color=red>When does this become a factor?</font color=red>
When the rock/stump you want to drive over is 6.8"./w3tcompact/icons/laugh.gif
If everything on your land measures 6.6" or less then the BX would/could work for you. I didn't take the time to measure everything at my place but my BX22 has been a dream/w3tcompact/icons/love.gif. C
   / Ground Clearance on BX2200 #3
I've run into clearance problems a couple of times with my BX. So far it's only been a problem when I have the rear blade mounted. It hasn't happened everytime, only occasonily. I have the Woods RB60 rear blade and it's got a 15" moldboard. I think that a rear blade with a 10-12" moldboard would suit the BX better.
I like the Woods blade, and found it to be heavier duty than the smaller moldboard blades I looked at.
Jim
   / Ground Clearance on BX2200 #4
Mark, If you are going to spend much time off lawn, then the BX is probably not for you. I am a enthusiastic BX owner, but all my work is done on two parcels of lawn and a driveway.
The overall height of the tractor does present some raising problems with three point hitch implements. I have a stone rake for sale because the BX only gives me around 5-6 inches of clearance when the implement is raised. The newer implements like the King Kutter XB series should solve that problem.
   / Ground Clearance on BX2200 #5
The only issue that I've had with a BX22 is not with the tractor - but with the backhoe. I have to occasionally cross a stream with 3 foot banks on each side and the hoe will hit as the tractor goes up the other side. If it would have been mounted 2 inches higher it would be perfect. I suppose it really depends on your land and its features.
Boat Trailer - NO Title (A49251)
Boat Trailer - NO...
JD 772-A Grader  (A47371)
JD 772-A Grader...
2025 Man Basket Forklift Attachment (A49346)
2025 Man Basket...
2007 Volvo VNL Truck, VIN # 4V4NC9TG77N443256 (A48836)
2007 Volvo VNL...
(4) Sumitomo 11.00 R22 Tires (A48837)
(4) Sumitomo 11.00...
2016 Ford Explorer AWD SUV (A46684)
2016 Ford Explorer...
