Ground clear
   / Ground clear #1
Ronlud
John Deere
This has probably been asked a bunch, but I've seen so much conflicting information.
I need to clear / sterilize a section of ground. And I mean forever, or as close to it as I can. What is the best method for this.
I've read about the chemicals and it sounds like rm43 gets me maybe ai year, but I need forever. Salt it ? It's not a large area, maybe 500-1000 sq. feet .
Thanks for the help !
   / Ground clear #3
What is this project for?
Bruce
   / Ground clear
This is to stop all weeds in a natural type area, where it has weed stop fabric covered by bark chips.
   / Ground clear #6
If there were such a chemical that would provide a permanent solution - I'd be concerned about its side effects. Toxic to humans or pets. Does it tend to bleed to other areas when it rains - etc.
There are more than a couple that would provide a LONG solution. However - not allowed in areas where humans or animals could gain access. Not allowed in areas where the product could bleed/drain into adjacent areas.
You are going to be limited to those products that will not harm the environment, humans or animals. To the best of my knowledge there is no chemical that has a permanent effect and meets these requirements.
   / Ground clear
What about salt or rock salt?
   / Ground clear #8
Kerosene will do it, and likely be as safe as any herbicide you can buy.
   / Ground clear #9
I once put out a salt block to see if deer would like it. They didn't care. It eventually totally dissolved in our heavy rains. It did nothing noticeable to the plants around it while it was there or afterwards.
That would be about 10 inches deep of salt on a 10 inch square.
Bruce
   / Ground clear #10
Agent Orange has it's followers, but with such a small area, black plastic will do.
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2016 CATERPILLAR 335FL CR EXCAVATOR (A51242)
2016 CATERPILLAR...
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
Willmar 4300 Wrangler Loader (A52128)
Willmar 4300...
2008 FORD F-750 (A50854)
2008 FORD F-750...
