Grinding transmission
   / Grinding transmission #1
guzzi guy
I've got a 2 year old Cub Cadet LT1050 that grinds when I engage the forward or reverse foot lever. It also won't go into neutral when I pull the rod out the back. The park brake doesn't engage either. If I fiddle around with it, sometimes everything works fine. Dealer says $1100 for a new trans! Any ideas?
Thanks.
   / Grinding transmission #2
Don't know about your Cub but at 2 years old isn't it still under warranty?
I do know on my tractor I have to lube all moving linkages with a penetrant spray every years or they stick / freeze up. Especially the linkage for my differentail lock.
No warranty, I bought it used a few months back. It worked fine until someone was horsing around and drove it into a pile of leaves. I looked underneath, and the only thing I see is a lever for the disengagement. It doesn't look bent or anything, but who knows. Maybe I'll play with that and see what happens.
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A54607)
2020 KENWORTH T680...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2011 KENWORTH T800 (A53843)
2011 KENWORTH T800...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2022 Adams CLC-1013 Conveyor - New (A53473)
2022 Adams...
