Grinding and welding on a Saturday afternoon!
   / Grinding and welding on a Saturday afternoon! #1
Ford960
South Carolina
Ford 960-5
As I was needing to fix a method to allow my Bush Hog 305 to float on the 3 pt hitch I read with interest the thread on the chain top link:
http://www.tractorbynet.com/forums/attachments/86158-what.html#post963126
But I decided that I needed a method to adjust the top link so I came up with this:
http://i43.photobucket.com/albums/e380/Capt-Ron/toplink4.jpg
This was an old top link that I managed to bend and so I cut the bent ball end off and welded a "U" shaped section of 1/4"x1-1/2" strap to the left hand threaded end. I ground the threaded section so that the legs of the strap were parallel. This gives the top link 5" of travel to allow the rear of the mower to float over high and low places.
A quick test over at my buddy's lot proved the merits of the system.
   / Grinding and welding on a Saturday afternoon! #2
Clever idea making the slot travel on the top link. That is much the same idea as the slot on my Howse rotary cutter...only in reverse. Good idea.
I found that about a 4" slot gives it just enough of travel to adjust for most "up and down" movement required while mowing.
   / Grinding and welding on a Saturday afternoon! #3
My howse also has a 4" slot int he toplink connection.. works great.
Soundguy
   / Grinding and welding on a Saturday afternoon! #4
Excellent suggestion Ford ! :)
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
UNUSED RAYTREE RMBD72S-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
2016 John Deere 7210R MFWD Tractor (A53342)
2016 John Deere...
UNUSED JCT 60" HD HYD CONCRETE MIXER (A51248)
UNUSED JCT 60" HD...
