gribaldi & salvia superior 394 problem
   / gribaldi & salvia superior 394 problem #1
joesharps79
saint marys wv
1020 john deer
I have a superior 394 mower and last year the guard bar broke under the first guard got a new one and finished the year this year the new one broke and i had welded the other one back together over the winter so i put it on it lasted about 10 more acres and it broke i wasnt running it hard and the hay isnt that heavy actually short and thin this year.. Does anyone have any ideas of y it is doing this and what i might be able to do to fix all help will be extremly appriciated got to get it fixed as cheap as possible and as fast as possible still have to finish first cutting cant keep buying gaurd bars to break lol
   / gribaldi & salvia superior 394 problem #2
That is the same mower I have. I use it for roadside mowing and rough field mowing. The only time I have broken mine is when I hit a rock or got into gravel with it. Lengthening my top link to roll it back a little helped alot. It kept the teeth and blades out of the dirt.
You may not have that problem on a good hay field though.
   / gribaldi & salvia superior 394 problem #3
I have the 394 as well. I am having an issue with continually breaking the first guard (the one closest to the power head). Any thoughts on why only this one? It sounds like a turkey in a lard bucket constantly pecking. It will run smoothly at any RPM when not in hay, but as soon as I start into the grass it starts the pecking noise and then gets louder until it breaks the guard.
   / gribaldi & salvia superior 394 problem #4
Your gaurd bar is probably broke under the blade head. Mine was doing that and when I took the section bar out and the hold downs loose I found it. My advise would be take the gaurd and section bar off and go through them fixing loose gaurds and blades. With a few wrenches, hammer and some rivets you will have it back in A1 shape. If the gaurd bar is broke you can weld it to the blade head but when you do finally order a new guard bar you will have to also order a head about $25 extra. Hope that helps. FYI, the reason it probably broke is when you get a pile of cut grass on the blade a try to flip the blade up and it bounces or lift the bar up under something putting pressure on it( basically anytime the staff is flexed.)
   / gribaldi & salvia superior 394 problem #5
I know it's been a while since you posted this question, so I was just wondering if you got it worked out or not? I bought a used one this summer, and was using it just the other day and it broke just about where you described. Unfortunately the guard bar foot broke also. I ordered a new one, and I will try to have the old one welded at local machine shop. I bought a whole new guard bar with guards and foot. I could have bought just the guard bar and foot for a whole lot less, but figured I could use the old guards as replacements if the old one can't be fixed.
Thanks,
Tim Robinson
   / gribaldi & salvia superior 394 problem #6
Thanks,
Tim Robinson
Well he were are again 😺. I am having the exact same problem with the guard bar breaking at the foot. I bought a used one and it broke immediately. We took it apart only to find that it had been welded several times. We welded it back together and cut about an acre and it broke again. We replaced the entire bar, with the foot and guards. It broke again after an acre of mowing hay. I am new to hay cutting but have been mowing cautiously. I’m at a loss. Seems like a common problem with these.
2007 GREAT DANE CONVERTER DOLLY (A51222)
2007 GREAT DANE...
2015 INTERNATIONAL PROSTAR 122 SLEEPER (A51219)
2015 INTERNATIONAL...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A51222)
2001 KENWORTH T800...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A52128)
2020 New Holland...
