Greetings form NYS
   / Greetings form NYS #1
cadybrook
Remsen, NY
Deere, MF
I own another business, so the farm is just the wrong size- a little too big for a hobby. I have mostly old stuff, but all in good shape. Deere 3010 diesel utility (I'm told pretty rare) Deere 350 diesel crawler loader with backhoe, MF 150 diesel. Also a line of hay machinery and other implements. Both Deere's had to be overhauled due to coolant in the base. They now have spin on coolant conditioners (as does everything else I own.)
I have a specific question regarding the 3010. 1,200 hours since an overhaul. There is a slight "tick" in the engine after it warms up. I just checked the valve lash and if anything they were a bit tight. One of the nozzles (also overhauled) has always been wet externally and I wondered if an internal leak could be the cause of the tick as well as the leak. I'm also going to listen to the hydraulic pump with a stethoscope.
Regard- Cadybrook
   / Greetings form NYS #3
Welcome cadybrook, I would post your question in the JD forum as all your gonna get here is Welcome.
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2019 JGL 2632ES 26ft Electric Scissor Lift (A50322)
2019 JGL 2632ES...
2015 International DuraStar 4300 26ft. Box Truck (A55852)
2015 International...
TRANSMISSION JACK (A55745)
TRANSMISSION JACK...
Quick Attach Plate (A53316)
Quick Attach Plate...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
