Green PVC Pipe vs. White PVC Pipe
   / Green PVC Pipe vs. White PVC Pipe #1
Daughton
I'm trying to address a water drainage issue on the side of my house and was planning on using PVC pipe set in pea gravel with felt. Is it okay to use white pvc pipe with the drilled holes vs. using green pvc pipe with drilled holes. I've notice that green pvc is double the price.......any thoughts or suggestions is appreciate.
Thanks!
   / Green PVC Pipe vs. White PVC Pipe #2
I believe the only difference is in the wall thickness of the pipe.. The white sewer and drain is adequate for footer drains.
   / Green PVC Pipe vs. White PVC Pipe #3
There is Schedule 20, 35 and 40. Has to due with the wall thickness. #20 works well.
   / Green PVC Pipe vs. White PVC Pipe #4
White stuff is generally schedule 40 (don't use the really thinwalled stuff..it's pretty much garbage). Schedulae 40 with holes drilled will be fine for a French drain.
   / Green PVC Pipe vs. White PVC Pipe #5
Just yesterday I was in a plumbing store and saw 3" white PVC pipe with a wall thickness less than 1/8" -- I would guess even less than 1/10".
Color doesn't mean very much. The specifications for the pipe are usually printed on it.
2016 Ford F-150 Pickup Truck (A44572)
2016 Ford F-150...
2019 TY-CROP MANUFACTURING LTD DRY BULK TRAILER (A45333)
2019 TY-CROP...
2017 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A43003)
2017 INTERNATIONAL...
2024 Apex Hyperdisc T26 High Speed Tiller (A44789)
2024 Apex...
2007 Volkswagen Rabbit Hatchback (A42744)
2007 Volkswagen...
John Deere 710G Extendahoe Backhoe Loader (A44571)
John Deere 710G...
