Greatings All Came here for advice
   / Greatings All Came here for advice #1
hdgib
I recently bought a home in rural FL. I have 3.5 acres and another 3 acres of dry lake bed. My second hand box store disposable rider mower died again (second time in 2 months) I don't do much to need a tractor really, but I do move things around and would probably enjoy playing on a tractor rather then buying a mow only lawn mower. With the tough grass needs and the size for a new rider or even a good used one it almost puts me in the used compact tractor price range.
I found a gray model Kubota B6000E no attachments but from what I have read here the reverse engine would cause unneeded problems, it was $1500. Someone else has a 1988 B7100-HST with turf tires and a 'needs a little work' 48 inch belly mower (wheels and u-joints) for $2200. Does this also have a reverse engine? I have an old 1943 Ford 9N that needs break seals and a King pin still up in TN with a bush hog, grader blade, dirt scoop, cultivator, and found a front end loader for it too. I will be bringing it all down here to sell at some point. Will any of the implements work on the Kubota? (I know the loader won't :laughing:)I read somewhere about cat 1 and cat 2 3PHs and 1" 10 verse 25 MM shafts and all, and really don't know what they are talking about other then size and groves. If I have to buy all different attachments the I might as well keep the 9N get it fixed and get a finish mower. I thought the B7100-HST being a 3 cylinder Diesel may have more power then the N And of course being a few decades newer might be easier to maintain.
I might drag around a few trees, run a 3PH log splitter (if the tractor has juice) Use the dirt scoop to move things around and maybe bush hog the tall grass areas. Maybe even get a tiller for a 1/4 acre garden.
Your thoughts?
Thanks for your time.
HDGib
   / Greatings All Came here for advice #2
:welcome:
Good introduction. :)
I think a "modern" tractor with HST tranny, Cat I 3 ph, with turf tires in the 25-35 hp range would handle/fit your 9N attachments. I won't/can't comment on which Kubota to get, as I'd be going green :D.
But you should find some brand that has a good dealer close by, and then enjoy fixing up the Ford 9N.
Post your requests for info in the Boards (i.e. Kubota) for more specific help.
Enjoy the ride. :D
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
1989 Freightliner Cabover FLA086 (A52748)
1989 Freightliner...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
Toro Mower (A50324)
Toro Mower (A50324)
