Greasing the MMM....
/ Greasing the MMM.... #1
Volfandt
Veteran Member
TN
2004 Kubota BX23, 1966 WheelHorse 856
How often do you grease your mandrels & pulley on your MMM?
I squeaze about 5-10 pumps ea., every 5th mowing. Which is about every 8.5 - 9.5 hrs.
Volfandt
/ Greasing the MMM.... #2
I grease mine every 4 to 6 hours of use with about 5 to 6 pumps of the grease gun. I use the high temp. grease in it. A lot of time's I will use 3 or 4 pump's after only a couple of hours use. I visited my dealer the other day and he said one new spindle assembly for the outer sides of the ZD21 Pro Deck would cost me about $360, (included labor) if I ever needed one. He said the center assembly would cost more to replace.
Grease is cheap insurance. /forums/images/graemlins/grin.gif
Curt
/ Greasing the MMM.... #3
Every 3 tpo 5 hours. I can hear the difference if I wait 8 hours and then grease, so I figure it must be under lubricated at that point. It is much quieter after a greasing.
I have not mowed since ~ June 20th. I'm not sure I remember how. Know any good rain dances? /forums/images/graemlins/grin.gif
/ Greasing the MMM.... #4
I grease mine every 10 hours like the manual says. I usually do 6 pumps. I also like to grease the heads every time I have the blades off until the grease starts to come out from underneath. That way I'm sure they're full. The first time I did this it took a LOT of grease before it started coming out. I guess with 6 pumps every 10 hours it wasn't keeping them full or they weren't full to begin with.
Jeff
/ Greasing the MMM.... #5
When I got my MMM on my B3030 this spring, there was a bearing with barely no grease at all. I added around 1/4 of a tube before the grease came out on the other side. I wasn't very happy about that.
I grease my bearing every 10 hours.
/ Greasing the MMM.... #6
I tend to completely clean up the MMM deck and grease all the zerks every other mow. Each mow is about 3 hours probably, so I guess that's about every 6 hours....roughly speaking.
I agree with the other comments, grease is cheap insurance.
Kevin
/ Greasing the MMM.... #7
I grease all zerks after I finish mowing and clean everything up each time. A little over the top, but easy enough for piece of mind. /forums/images/graemlins/grin.gif
/ Greasing the MMM.... #8
</font><font color="blue" class="small">( I grease all zerks after I finish mowing and clean everything up each time. A little over the top, but easy enough for piece of mind. /forums/images/graemlins/grin.gif )</font>
Me too; actually I think the plate on my MMM says to grease the spindles with every use - have to go look now I guess.
/ Greasing the MMM.... #9
yes, grease is cheap, but I find it quite painful to remove the MMM even with the wheels rotated sideways. I have to do mine on a gravel driveway and it just doesn't work very well!
/ Greasing the MMM.... #10
Mike,
</font><font color="blue" class="small">( yes, grease is cheap, but I find it quite painful to remove the MMM even with the wheels rotated sideways )</font>
Can't you get to your zerks with the MMM installed? The only ones that are a stretch for me are the rear rollers. Other than that I can just lower the 3PH, pop off the two covers and go to town.
Kevin
/ Greasing the MMM.... #11
I can easily get to the outer two pulleys with the MMM on, but can't get to the one in the center without taking the deck off the tractor.
I use an air-powered grease gun with a non-flexible tube. I may be able to do it if I change it to a flexible hose, but then that would slow down the greasing of the FEL and backhoe. With the stiff tube I can keep the grease gun in one hand, and a screwdriver in the other hand to scrape out the dirt that gets packed in around the zerks on the backhoe and FEL, then with one hand push the gun onto the zerk and pull the trigger.
/ Greasing the MMM.... #13
Add a little pipe and bring all the deck zerks to one common accessible location.
The u joints will still be a problem
Egon
2020 John Deere 2633 Disk 29' 3" (A64047)
2020 John Deere...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
1998 FORD AREOMAX 9500(INOPERABLE) (A63569)
1998 FORD AREOMAX...
IRET13 Tricycle (A64047)
IRET13 Tricycle...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59912)
2020 KENWORTH T680...
