Backhoe Greasing Problem Bt900 Backhoe On L35
   / Greasing Problem Bt900 Backhoe On L35 #1
Keuka
Bronze Member
I'm having a problem greasing the lower swing pivot on my BT900 hoe on my L35 Backhoe. I read another post where someone else had the same problem.
The zerk fitting is located with so little head room clearence, that a hand operated grease gun can't get on it. I tried an offset 45 degree zerk but the swing cylinder hits it. I also tried an offset 45 degree grease gun tip with no luck. The original zerk is reset so a slide on grease gun tip will not work either.
I'm now inserting the offset zerk, greasing the pivot and replacing the offset zerk with the original fitting. What a pain and I'm kind of out of options.
There's a pile of L35 backhoes out there. Someone else must have encountered this problem. I sure would appreciate some help.
   / Greasing Problem Bt900 Backhoe On L35 #2
Hi Larry.
(replied to your pm )
For anyone else:
The solution I came up with works great. I bought a brass 90' fitting.. installed the fitting on the hose..then the coupler on the fitting. The total lenght is 2 1/8". I move the boom swing all the way to one side, the swing cylinder moves completely over the zerk and out of the way. Plenty of room now.
Thanks for the reply. Sounds like the ticket.
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
Manac Walking Floor Trailer (A50322)
Manac Walking...
1998 FORD CRANE (A52472)
1998 FORD CRANE...
2013 ISUZU NPR STAKE BODY TRUCK (A52577)
2013 ISUZU NPR...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
