Greasing my 2210's fittings and have some questions
   / Greasing my 2210's fittings and have some questions #1
nfernandez
Bronze Member
Byron Center, MI
John Deere 2210
I purchased my JD 2210 last year and I want to grease all the fittings. I read that you don't want to mix certain lubricants, but how do i know what was used before if I can't contact the old owner? Is it best to just clear out all the old grease first to be safe? If so, how do you do that? I understand how to add grease with the fittings, but never took out all the old before.
   / Greasing my 2210's fittings and have some questions #2
Use a good quality grease & grease until you see the new grease come out.
   / Greasing my 2210's fittings and have some questions #3
Ditto on the last response. Use grease containing lithium. You'll be flushing out the old stuff fast enough that a little mixing won't be an issue.
   / Greasing my 2210's fittings and have some questions #4
Sorry, meant to say moly not lithium for the grease additive.
   / Greasing my 2210's fittings and have some questions #5
If you have worries, regrease the fittings more often at first.
Look at Deere's website on grease:
John Deere Grease JohnDeere.com
They have some greases that are listed as compatible with most others. Personally I use Deere SD Polyurea on just about everything, it seems to be a good all around grease.
2010 International 4300 TMA Attenuator Truck (A52377)
2010 International...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2016 Ford Fusion SE AWD Sedan (A53424)
2016 Ford Fusion...
2015 Jeep Cherokee Latitude SUV (A53424)
2015 Jeep Cherokee...
43030 (A51691)
43030 (A51691)
