Greasing main driveline front (JD 1023e)
   / Greasing main driveline front (JD 1023e) #1
El Scorcho
CT
John Deere 1023E
If this is the wrong forum, I apologize.
I just recently switched the trans/hydraulic oil and have been going through the maintenance manuals and remembered a problem I had while greasing.
In the service lubrication section of the manual, we are told to grease the main driveline front. The picture says, "note: parts have been removed for better view."
What I saw when I was underneath the tractor was a dime-sized hole through which one is supposed to put the grease nozzle to the fitting. You can spin the flywheel to move the shaft, but you can't do this from underneath the tractor.
After a few frustrating minutes of trying, I decided to attempt to grease from above.
This bit of advice is for a JD 1023e (but probably relevant for the 1025 and 1026, if not others).
I lifted the hood and took the two side panels off. There was no access there, but in doing so, I saw there were 4 screws holding a cover above the driveline. I removed the four screws, took the cover off and saw the grease fitting. From this position, you can spin the flywheel and watch the fitting rotate into position.
It took maybe an extra 5 minutes to remove the side panels and cover and put them back on, but it was an easy fix for an otherwise frustratingly small hole.
I hope this helps!
El
   / Greasing main driveline front (JD 1023e) #2
Thank you for this detailed information. I was about ready to start bending oil lines to gain access to this front driveline lubrication fitting. Piece of cake if you follow your instructions.
   / Greasing main driveline front (JD 1023e) #3
El Scorcho, that's a great tip for all JD 1023e owners :thumbsup: and for that you win a...
2005 Big Tex 23ft T/A Flatbed Trailer (A52377)
2005 Big Tex 23ft...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
Freightliner Tender Truck (A55301)
Freightliner...
Brush Bandit 200UC Towable Brush Chipper (A52377)
Brush Bandit 200UC...
1984 Ford LTD Crown Victoria (A52377)
1984 Ford LTD...
2011 Caterpillar 299C Two Speed Compact Track Loader Skid Steer (A52377)
2011 Caterpillar...
